My RV-6A (O-320 150 hp carburetor) has suddenly developed a starting problem: Sometimes it starts right up, other times it cranks away without firing.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I noticed that if I stop cranking by allowing the key to spring back to "both", and then hit "start" again sometimes it will start up instantly, other times it just continues cranking away merrily without firing. So far, I have been eventually able to start the engine by repeated attempts, but it is hard on the battery.
Do I have a Mag Switch problem, or perhaps a mag issue? I realize that in the "Start" position, one of the mags is disabled to allow the timing to be retarded for start.
Mag checks, including hot mag check, are all normal, everytime. The only issue is on start. Anyone had this problem?
Thanks!
