Paul Johnson
Member
I'm trying to figure out how to wire my ignition switch. I have an Aerosport O-360-A1A with a mag on the left and LS Plasma II+ on the right side. The mag needs its P-lead grounded to be OFF and the LS needs 12v power to be ON. I'm also trying to use a conventional OFF-R-L-BOTH-START keyswitch. I thought about using a relay to invert the logic (NC contacts would provide power to the LS system when the relay is not energized), but that would leave the LS system "hot" when the keyswitch is OFF and master power is ON. Am I overlooking a simple solution, or do I need to abandon the keyswitch idea and go to a couple of toggle switches and a pushbutton starter control? My only opposition to this is the big hole it would leave in my panel.
Other must have faced this issue before, but a search did not turn anything up.
