Curious if the backlighting is ok, being that it is not adjustable? So yours is battery backup, then ships powered when avionics bus alive? I'd prefer the night vision green of the davtron, but not sure it's worth the additional $100. That and it would have adjustable dimming. ThxI have the FDS GT50 in my RV-10 panel and like it very much.
yours the green night vision backlighting? I just need something easily readable especially at night. Must be a good/easy timer as I'm starting my ifr training. Those are my needs. My EFis carries all the other functions so really after the timer.I have the Davtron 803 clock/OAT combo in my Warrior. I had installed last year and it has been great. You can configure it to start timing by pulling one pin to ground with a squat switch or other input. It has dual Zulu/local clocks, a flight timer, an elapsed timer, and can display OAT in C or F as well as bus voltage. I would recommend it if you need those functions.
