I think my injector was assembled wrong or IAW another setup. When I put it on the levers for the throttle and mixture don't rotate along with where the cables would go. The throttle on the left in the picture is in the closed position and rotates straight up when open which would cause the cable to bend around the intake. Then the mixture lever is on the right in the picture is full down and the bracket I installed doesn't reach it even if I unscrew the lollypop all the way. As for the fuel fittings the small one is on the bottom when I believe it should be on the top. The larger one is on the left side and you can just make out a little of the red cap under the mixture bracket. Any help would be appreciated. Thanks
http://i1299.photobucket.com/albums/ag62/nbachert/photo_zps63ac94e2.jpg
Nick
Nick
