Vans101
My oil scavenge pump is leaking at the second (middle) seam. The base mounting gasket is new and that is not leaking and the top cover gasket is also fine however the one in the middle is leaking.
I removed the scavenge pump from the accessory case and I thought I could simply remove the 4 nuts from the studs and pull it apart however it is stuck on. I do not want to force it and the manual does not really provide guidance.
Has anyone performed a gasket R&R on this unit before and if so can you please provide a little advice?
THANKS!!!
