ENGINESEVO
Member
Could anybody explain what does the engines codes mean (A,,B,C, etc). I?m planning to buy and overhaul an used O-360 and I need to know if it will fit in my RV-8.
An RV-8 (non A) will fit almost ANY Carbed (O) 360 except the series out of a Grumman tiger/Cessna Cutlass (I think it's a -G? Horizontal mounted carb). The A series are the most common.
...O-360-A4K from a Grumman Tiger that would not work in either -8 model.
The same sump with a rear facing carb. is also used on these other models...
-A1G6
-A1G6D
-A2G
-A4G
-A4J
...and also won't work without carb, sump and intake pipe swapping at a minimum.
Not all -A models are created equally....![]()
Hi Steve,
I had previously downloaded some of your links. However I can no longer open the files. I am trying the links again, but they seem to not work.
http://www.rv7factory.com/files/engine_choices.pdf
http://www.lycoming.com/support/trou...ces/SSP108.pdf
If you're wanting some 'light' reading on lycoming engines you might like to look at the Key Reprints of the Lycoming Flyer (http://www.lycoming.textron.com/supp...e/key-reprints)
Would anybody have these documents? Specifically "engine_choices.pdf".
Thanks in advance.
AJ
