Majorpayne317641
I am reading the Lycoming service instruction 1059E that states I must use a choice of 3 grease type lubes to apply to the cam and other parts. Then a mixture of STP and mineral oil for the bearings and the rest. I tried to find Lubri-bond, MOLYTEX EP 0, and the Castrol Contractors special ngli #1. The only one I tracked down was a drum of the contractors special for $800. Does anyone know where to get this stuff and not in a spray can for the Lubri-bond? I usually use engine assembly lube for car engines. What’s with the crazy choices they gave? It’s like the tested with the most unique products out there.
