S Sylvio Member Mar 23, 2015 #1 Should I put the luggage in front of or behind the first? Traveling alone or with someone... Tks
BruceEicher Well Known Member Mar 23, 2015 #2 Majority of weight in front luggage compartment when with a backseater, in aft compartment solo. You have a weight and balance calculator?
S Sylvio Member Mar 23, 2015 #3 BruceEicher said: Majority of weight in front luggage compartment when with a backseater, in aft compartment solo. You have a weight and balance calculator? Click to expand... No, I have not. Thanks for the reply.
BruceEicher Well Known Member Mar 23, 2015 #4 Sylvio said: No, I have not. Thanks for the reply. Click to expand... Take a look at some of these threads to locate a calculator for your ipad, computer, or such. You have a lot of loading flexibility with the -8 but you want to be aware of how it changes take off, flight and landing. http://www.vansairforce.com/community/search.php?searchid=23616854
DHRYCAUK Active Member Mar 23, 2015 #5 I download an app for my iPhone, WnB Pro ver 2.1. It works awesome and is flexible to set up for your airframe.
