I was starting to rivet the first lower wing skin, when I noticed that the skin was not laying flat on the wing ribs. Each dimple was a short column with 1/64th to 1/32nd gap between the rib and the skin. The skin dimple appears a larger diameter than the rib dimple.
This must be the down side of years of delay in construction, and a loss of brain cells.
I cannot remember the tools I used previously, but this time I used a DRDT, Cleaveland Hand Squeezer and Cleaveland Spring Back Dimple Dies to dimple the ribs and skins. I upgraded my tools to do a better job ( Go figgure )
Any tips or techniques I should try?
