zkvii
Hi,
I give up.... I don't see how / what I'm meant to do for the lower baffles and the safety wire. I understand I need to use the 'brake line' to protect the oil return, but questions:
Does the wire go above or below the oil line - I think it is below
How do you protect the AL ends from the Stainless wire chewing through it
Where do you 'pull together' the wire
Should it be twisted the whole way or just the ends
How tight should the baffle to cooling fins be
Has someone got a few close up photos of this area - my normal websearching has proved fruitless
Carl
Carl
