so.....took the filter housing off to do a bit of fiberglass work. Seems it was about .75" off center from the Sam James Cowl intake ring. Upon removal I was a bit (actually a lot!) surprised to see that quite a bit of fuel had pooled up in there. It's an RV9 so it naturally is aimed down hill and turns the elbow of the induction tube into a sump. Oh, and, forgot to say it's vertical induction IO-360.
Has anybody else experienced this and, if so, what did you use as a drain? I was thinking about using one of those rubber tubes that has the end pinched closed but opens when squeezed.
Any other ideas?
thanks ahead of time
danny
Any other ideas?
danny
