Hi all, I have a superior IO-360 engine with van's oil temp gauge. The oil temp reads 130 to 140 max and around 80 to 100 on the ground. EGT and CHT are within limits. Someone suggested that the vans' adapter on the oil probe may be preventing the probe from getting low enough into the oil stream to give a good reading. Has anyone else experienced this? Also, has anyone tried using a different type of probe with van's oil temp gauge that makes the adapter under the probe unnecessary?
Thanks for your help,
Joe sends
Joe sends
