I am using a GRT 4000 EIFS and my indicated cylinder temps are around 300 degrees with an outside tempo of 70 degrees. My oil temp is around 220 plus degrees.
I am using the cylinder temp sensors from Tanis Engine Heaters that are installed between the heating elements and the cylinders. I am wondering if the sensors are not calibrated or if this configuration report lower than actual.
Thanks Steve
RV7A Completed
Thanks Steve
RV7A Completed
