Gregg Brightwell
Ok guys, I searched through many posts, but can't find much. I am ready to put on tank baffles, and am thinking it might be nice to have a low fuel alerting system. Especially valuable if I don't go glass, and use Vans fuel gauges instead.
I have read about the optical unit from aircraft extras. I have also read about the micro switch on a float that Spruce sells. Have any of you used the latter? Does it work?
Now, I know there are those of you who will want to respond with "you don't need that" , and "manage your fuel and you won't have to worry about it"...![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
But please don't. I'm just curious as to what folks have successfully used.
For the record, I am using the standard Stewart Warner floats for fuel qty.
Thanks!
Gregg
Thanks!
Gregg
