I need to ask the forum if I have an issue here. I have 3 photos attached showing CHT/EGT with #4 cylinder having unusual readings. The engine is a o320 150hp. At full power, the EGT is unusually low 1159 and 349 CHT. At cruise power, EGT is closer to other 3 cylinders as well as the CHT. At low power settings, all temps are close to each other. Full power settings in climb is where the temperature gaps are at the highest. All the variables are on the photos and looking for guidance or is this behavior normal?
![cruise power1.jpg cruise power1.jpg](https://vansairforce.net/data/attachments/30/30787-e43dab5274a48357cf8e141c6af4f3f6.jpg)
![low power1.jpg low power1.jpg](https://vansairforce.net/data/attachments/30/30788-08f2295f98b573b81cd495b360b9ebca.jpg)
![full power1.jpg full power1.jpg](https://vansairforce.net/data/attachments/30/30789-58b955dd7db28f5a789ac8423a19dbbd.jpg)
