ron sterba
So I mounted my oil cooler on the firewall because of the cracking on the corner angle of the oil cooler mounting as reported. Now I have a 3" scat tubing running from the rear baffle plate to the firewall mounted oil cooler. I would like to install air louvers at the rear baffle plate rather than the bottom of the oil cooler. Thinking if the louvers are at the bottom of the cooler would make the scat tubing always under pressure. Course not sure it even makes a difference so Iam asking your thoughts on the subject.Thanks guys
Ron in Oregon QBRV9A N421HJ
