Marc DeGirolamo
One of my fuel caps which are now several years old would not stay closed the other day.......I tried to adjust it and broke the pin. I installed a new pin, new o-ring and shaft seal but did not solve the problem......Upon closer investigation the corners of the tab which is pushed down were worn a little, enough that it did not want to go 'over center' and snap closed. Are there parts available for these caps or do we have to buy a complete unit ?? Incidently I fixed it temporarily by filing down to give a square corner again but this will wear out in time.......wondering if anyone has experienced this with these caps....thanks
