Sure would like some guidance from you guys. How are we to comply with this statement in Notification 14-07-03?? Have the lawyers gone astray??
Van’s Aircraft recommends that owners and/or operators of all RV models comply with the applicable recommendations in SAIB HQ-14-16.
http://www.rotor.com/rotornews/April14/HQ-14-16.pdf
Read the last paragraph of the first page.
My understanding is that if a nut is bad, torquing it to the standard value will cause it to crack.
Inspect the nuts for cracks... If no cracks, nut is ok.
How many of this style does Vans provide in the kit?
Are they use in the -12s?
Pulled the notebook and looked at the parts listings for the subkits. Found that Van's supplied 29 locknuts for my vintage RV-12. First person to locate all of them in the plans, WINS!
Empenage Kit
Bag 2671 6 - MS21042-6
Fuselage Kit
Bag 2720 6 - MS21042-08, 2 - MS21042-3
Wing Kit
Bag 2624 2 - MS21042-08
Finish Kit
Bag 2772 2 - MS21042-08
Avionics Kit
Bag 2801 1 - MS21042-3
Powerplant Kit
Bag 2812 9 - MS21042-3, 1 - MS21042-4
Empenage Kit
Fuselage Kit
Wing Kit
Finish Kit
Avionics Kit
Powerplant Kit
Spent a little time looking. Found all of them BUT one. If someone finds it in the plans, please let all of us know! Keep in mind, my plans are 4 years old, so Van's may have re-numbered some of the plan pages.
RV-12 MS21042 Metal Locknuts
Empenage Kit
Page 11-06 - Trim Motor Attachment to Tray (6)
Fuselage Kit
-08 Page 21-20 - System Block Stud Bolts (6)
-03 Page 23-07 - Vent Doors on Side of Fuselage (2)
Wing Kit
Page 16-04 - Ground Wire to W-1205 Bracket (2)
Finish Kit
Page 38-09 - Cowl Closeout Bracket
COULD NOT FIND the 2nd
Avionics Kit
Page 42-11 - DG Clamp for GPS Wires
Powerplant Kit
-04 Page 46-16 - Starter Motor Ground Connection
-03 Page 45-03 - Battery Ground to Battery Tray
-03 Page 49-09 - Water Radiator Door Push Pull Cable Clamps (3)
-03 Page 49-17 - Oil Cooler Line DG Clamp
-03 Page 49-05 - Water Radiator Bolts (2)
-03 Page 49-12 - Oil Cooler Bottom Guide Bolts (2)
