mbert
Active Member
Any recommendations for shops to get an IFR pitot static check and transponder check in Oklahoma or North Texas.
And have him do a dynamic balance on your prop while you're there! :)
And you also have to install a new G3X panel while you're here :eek:
Give me call if you don't mind burning the gas to get here, lots of RV's around to drool on!.
That sounds like a good idea. Walt, how much for pitot/static and transponder tests for IFR certification?
(RV-8, 460 hours total everything, Dynon D180, Garmin 327 transponder. Recently removed the steam altimeter & also added a Dynon heated pitot )
On a second line item, how much additional for the prop balance?
(Titan 0-360A1A, Hartzell C/S)
