tectweaker
Looking for some space for my Rv3 at Livermore . It is a pretty small plane so should easily fit in with a high wing and/or another Rv in a medium hangar.
Looking for either shared or full hangar... need it within next couple weeks.. any leads would be appreciated.
Might also consider some of the other airports - SJC & HWD etc...
I used to fly out of KLVK and think you might consider looking into renting an end room on the south side, if one is available. After moving and returning for a visit I put my RV6 in one for a few days. It was a challenge and wouldn't do it again but your RV3 is, I believe 3-4 feet less wing span so it should fit. I know that some small experiments were stored in end rooms. If I remember correctly they have full width roll up doors. Larry
looking at all options
please let me know if there are any other places - i might have to take something close by for short term...
Two possibilities
I sent you a private message regarding two possible hanger rentals at the Livermore airport.
Thanks so much on the leads. I am following up on the two leads already. Is somebody has a high wing aircraft then it will make it for a very easy fit.
Open to other airports in the area as well.
Byron
A little bit of a drive up the road from LVK, but Byron (C83) has a couple open hangars. It's not at Livermore, but it's a great airport, especially for a rural farm community (...that I'm rather fond of).
