Looking for critique of my panel layout. I have hidden all the structure / components behind the panel for clarity, but they are accounted for.
Configuration
1. Tip-up RV-9A
2. Current layout works around stock panel supports (one will be notched some)
3. Left EFIS is a Dynon 180, Right is a 100 (2nd set of gyros for redundancy)
4. GPS switch is to switch HSI input from 696 to 430
5. I can reach transponder form left seat. Also checked viewable angle on Garmin 327 and location will not cause a problem
6. Dynon?s are shallow enough to avoid interference with tipup re-enforcement
7. Battery back up in Dynon 180
8. Will use hand held radio for back up com
9. Already have map box installed (so don't suggest I move it)
Requirements
1. Wife is a pilot, so need EFIS viewable from right seat
2. IFR
3. Desire stock height panel and no subpanel to maximize entry / exit room
Alan Jackson
Hartselle, AL
Configuration
1. Tip-up RV-9A
Requirements
2. IFR
Alan Jackson
Hartselle, AL
