Jamesey
Plans show to get the vertex of the longeron flush with the roll bar support. No way I could do this without taking a vey small crescent filing out the longeron to clear the nutplate on the roll bar support. Am I alone on this?
Jim D
Hi Jim,
I did the longerons about a month ago. I did NOT have the issue you describe.
Alex
Had lots of problems but not that one
I'd be VERY cautions about making any cuts in the primary longitudinal load-carrying piece of my airframe. I'll admit I'm an aero guy and not a structures one but there are several more knowledgeable here on the forum and I'd be interested in their opinion.
Wayne 120241/143WM
To paraphrase an earlier post of mine:
Double-check all of your work on the longerons so far. I found this RV-12 adage to be substantially true: If it doesn't seem to fit properly, you likely did something wrong.[/I
