E ezetom Member Dec 28, 2016 #1 Does anyone have a part number? Im doing a panel upgrade, and I cant seem to find mine! Cheers Tom
hgerhardt Well Known Member Dec 28, 2016 #2 In case you're installing a G3X, remember that you can display ignition timing directly on the engine page. In fact, Lightspeed just released an adapter so that you no longer need to wire in an op-amp to make the signal readable. Other EFIS's may also be able to display timing. Last edited: Dec 28, 2016
G GregMac Active Member Jan 3, 2017 #3 Lightspeed Simpson Display SKU M14500120 will get the job done. Cheers from Western Australia
