Please look at the pictures below, I am running an Airflow Performance with a Lightspeed Ignition. The fuel lines to the injectors pass within about an inch of the coil. My concern is that if a plug wire comes off the coil, the spark from the coil will jump to the fuel line and cause a fire...
Is there reason to be concerned?
Has anyone else thought about this?
I imagine that even people with Silverhawk FI would have the same issue as the lines run nearly the same path...
and
and
