Full disclosure.
This should have been the very first thing I did when I received my QB fus but I got caught in the Grove gear fiasco and didn't have them at the time so I moved on.
Fast forward to today where I rolled the fus inverted to begin the gear install process. The instructions say to level via the F-822-1. On a QB this is not accessible from the outside. Am I meant be crawling under the fus and placing a level up on the cockpit floor or have people had success leveling elsewhere? I was thinking since I have the tail surfaces back off I could level at the F-819 aft deck where I leveled the fus for the tail group install.
Where did you measure for level when installing your gear?
I am thinking between the two directions the lateral level is more important than the longitudinal level.
If you installed Grove gear then any helpful advice would be appreciated.
I already see I am going to be required to relieve the skin a bit to get the outer saddles in.
I was also looking at the Vans out wear plates and the #40 access holes pre-punched in the skin. Is it just me or do they not quite line up?
As always, thanks in advance for your input.
