10_year_plan
I'm New Here
I want to arm myself with the knowledge needed to pick out tools. What capacity receiver and CFM/PSI compressor did you get? was it enough for the job? too much?
Did you get a reversible air drill? Do you think you can get away without one or do you really need that switch lever?
what sort of drill RPM is best value for money? I know "higher the better" but if I get one that only spins up to 1800 rpm, am I missing out on something important?
I do want to get a DRDT-2, but I would rather put the front end on a steel frame that I make myself, is this possible?
I would like to use a pneumatic squeezer, is it okay to use an alligator one or does it have to be in line?
For the squeezers, can I make my own yokes with the right steel?
Anything on tools that helped you along in your build process that isn't common knowledge?
