RVG8tor
I am starting my leg fairings an wheel pants. I am a little confused by the instructions. There is a step after you cut the fairing to length using he plans template where they have you fit it to the leg and use spring clamps to attach it to the leg. It is then that they want you to drill the hinge to the fairing. If I read this correct they want this done with the fairing on the plane, or can one do this on the bench. Once you have it clamped in place and know here the hinge needs to go it seems you can drill the hinge to the fairing on the bench but maybe I am missing something?
Anyone who has led the way, I sure would appreciate some amplifying information. 1.1 hours to go till phase two and a trip to Texas for paint!
Cheers
Mike
Cheers
Mike
