Ironflight said:I'm on roll trim indicator #2....it had some sort of loose connection in the back that caused the whole thing to go dim. Ray Allen said that wasn't possible, but they'd send a replacement anyway....I found out this is not uncommon.
Rick_A said:It occurred to me that my MVP-50 will display Trim indication and is probably more reliably than the RA LED indicator. Only problem is that I've already cut the hole in the panel for the Ray Allen indicator .
Any idea's on anything else about the same size as the RA LED's to fill the hole?
