danielhv
Ok... To begin with, check out this thread to see what I was attempting:
http://www.vansairforce.com/community/showthread.php?t=32421
Now, here we go! I should have just stopped and got someone to come help me... This has been one of those "I think I'll get it this time" and I never do problems... I am afraid I have completely butchered my spar and counterbalance ribs.
I made the reinforcing plate like Frank suggested... but when I was putting the shop head on the rivet, it buckled the reinforcing plate, should have seen that one coming.
So... I re-made one out of .042... Put it on there, and it worked out ok... but the two original problem rivets STILL would not lay down straight. I just don't get it. Nothing I have tried will get these *******s to set correctly.
I've probably drilled these rivets out 20 times over the past 2 days, seriously, no exaggeration...
So I finally let my temper get the best of me... I said to **** with this... I'm leaving them. I am not drilling them out again. Then to top it off, two of the holes I drilled for the reinforcing plate was too low!! So I could set the rivets after setting the retard rivets next to them.... geez... I once again said **** with it, and threw the only 2 cherry rivets I had in there. So, I post my masterpiece of frustration, headache, trial and error, and failure here for all to see. I should have stopped... I should have drug this out 3 days instead of the 2 it has taken me. Now I am likely to have to replace the spar and ribs and everything that is already riveted to them. Somebody shoot me.![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
