Could someone explain this to me. (I believe I got it off one of Mike Busch's Webinars)
It was about keeping your EGT's constant as you climb, the idea being to keep the mixture right, ie leaning it as you climb.I can't remember how that works.
Maybe Busch, maybe John Deakin.
John covered the subject in a Pelican's Perch article back in January 03. I suggest you do
not read the article, as (1) it makes the subject far more complicated than necessary, (2) offers a great many target numbers which are not universal, and (3) centers actual operations advice around the basic Continental fuel delivery system, which is nothing like the FI found on the typical Lycoming/Lyclone in an RV (basic Continental meters fuel based on RPM, while Bendix/Precision/AFP meters based on mass airflow).
That said, there is a
terrific illustration published as an addendum to that article; a Bonanza owner kindly made two climbs, one without leaning and one
leaning for constant EGT. The basic operational concept is true for all, and is illustrated very well:
http://www.avweb.com/media/newspics/182093_second_and_third_climbs.jpg
The fundamental assumption underlying lean-in-the-climb is that full throttle fuel flow is sufficient to result in an EGT approximately 150~250 ROP. Which is better? You're read that debate here; some (including me) argue that 150 offers full rated power, while others feel 250 is mandatory for cooler CHT. Neither position is wrong, and most users, if within the range, are not going to change what they have in any case.
So yes, note EGT at 500~1000 feet, WOT, and maintain that target EGT in the climb. It is not necessary to be real fussy about maintaining an exact EGT value. KIS.
