whd721
My left fuel tank appears to be leaking on the Inboard Tank Access Plate. The only penetration on that Tank Access plate is the Fuel pickup fitting. The blue dye stains appear to be coming from around the fitting not from the fitting itself.
This is the best estimate I can arrive at, without the plate being removed
My question is, Is it possible to remove the Tank Access Plate without removing the entire tank? Has anyone actually done it? Tips, Hints or guidance would be helpful.
The alternative is to remove the entire tank, I guess?
Just did a complete reseal on both plates on a RV-8 without removing the tanks. Not terrible on an 8.
As 74-07 (Rob) said, it can be done without removing the tank.
You can buy a small batch of proseal from Van's and a cork gasket to reseal the tank with.
A couple of suggestions; when you reinstall the cover plate, use 8-32 cap screws. Verify that SB 04-2-1 and SB SB 06-2-23 are complied with and write on the cover with a Sharpie that they have been as well as making sure their compliance is noted in the logbook. If either has not been complied with in that tank, you will want to open up the other tank. (Later in the production run, Van's added an anti-rotation bracket to the fuel pickup, so if the safety wire is missing, verify that you have the newer means of compliance.)
Good luck.
Leaky Tank Access Plate
Thanks 74-07 and N941WR,
Thanks to your encouragement I pressed on and was able to get the Tank Access Plate off. Two screwdrivers and a small Micro pry bar were sacrificed and modified in the process.
My RV9A was a project I bought to save time , BOY WAS THAT A BAD IDEA!!!!
I spent about 1/3 - 1/2 of the time to finish the RV9A, repairing something else I "discovered".
Fortunately I decided to remove the tanks and pressure test them before skinning the wing. Many leaks, Many leaks. My repairs lasted about 7-8 years, till now.
The current problem was the Anti-Rotation bracket. It was attached with two pop rivets, not blind rivets and no ProSeal. It took years for the fuel to work its way out through the rivets. On the Out side of the bracket, the rivet heads were covered with pro-seal applied around the exiting fuel line fittings. The rivet heads were buried at the very edge of the pro-seal, but totally covered, except for the blue stain. Also, the rivets did not leak when the fuel level was below the center the fuel Tank Access Plate. I scratched my head a lot chasing this leak.
Vans said this was an educational project!!
Following up on this... Is this what you saw? 8A left side under wing access panel.
I just had the same thing happen on my RV9A. It was a quickbuild wing that had sat unused for about 17 years prior to my finishing the kit as the 3rd owner. Never though to check the cork and rubber gaskets around the access plate and the fuel sender. Both started weeping after I got the aircraft flying. After talking to Vans the answer was to remove both and throw away the gaskets and just bond the access plate and sender in place with proseal. It was not hard to do just messy but is working well so far.
