Did a cold and hot compression check today and I can hear air escaping from the exhaust valve. I am wondering if it is worth pulling the jug(s) and re-lapping (inspecting) the valves. A guy on the field says that if you have an exhaust leak you should fix the issue, I have also been told as long as it passes compression test to keep flying.
cold
1 71-80
2 68-80
3 66-80
5 72-80
hot
1 74-80
2 70-80
3 68-80
4 76-80
Thanks a lot,
Jason
rv-6 o-360 (airflow fuel injected) 1,500 hrs on engine.
cold
1 71-80
2 68-80
3 66-80
5 72-80
hot
1 74-80
2 70-80
3 68-80
4 76-80
Thanks a lot,
Jason
