Hi everyone,
I'm at the stage where I'm getting ready to attach the rib flanges of the assembled leading edges onto the spar webs of my RV-7 wings. I've contemplated using the solid rivets called for in the plans, but I'm convinced that I'd end up regretting that decision if I buggered up my spars. I've read many accounts of builders using blind rivets to get the job done and I've decided to do just that, however I'm not sure which rivets to use. The builders that I've followed most closely have used the MSP rivets and I was planning on using them also, but it occurred to me that these rivets are made of Monel, and it would be fastening aluminum. The thought of galvanic corrosion occurred to me and I was unable to find anything already in the forums.
Monel itself is very corrosion resistant, but the aluminum spar is not. Has anyone out there that used MSP rivets had any problems with this? Do you think it would be a bad idea to use these rivets? I like the idea that the MSP rivet is stronger than an aluminum blind rivet, but if I have corrosion problems because of it, I'd rather go with the aluminum. Any thoughts and opinions are appreciated.
Brad
Brad
