flyingtaran
Member
Hey all
I made a pretty big boo-boo cutting the landing light hole out and am looking for opinions on a fix,
I didnt like my first cut out line so i removed the template, cleaned the sharpie line off and tried again, unfortunately when i put the template back on i inadvertantly put it on upside down and cut the hole about and inch and a half too far inboard,
I was thinking i could modify the bracket to house the light further inboard so as to line up with the hole, unfortunately the plexi will only have a half inch overlap on the aluminium rather than the 5/8" recommended & i'm sure there are many other considerations i haven't thought of, has anyone else run into this problem before and/or gopt any bright ideas for a fix??
cheers
cheers
