Any reason why I can't rivet the leading edge skin to ribs before I move on to the tanks? I've already fit / cleco'd / match drilled the joint plate, z-brackets, and tank / LE ribs, etc. and don't see much more that is done to the leading edge prior to final riveting to the main spar. I'm kinda cramped for space and would like to rivet the leading edge and move it into storage so I have more room to deal with the tanks.
John
RV-7A
Houston, TX
John
RV-7A
Houston, TX
