NROBB
Member
Does anyone have the LASAR and/or VM1000 DPU installation manual? My plane came with these two installed and now as i am reworking electrical wiring, i need the pin layout/diagram for the DPU unit and also the LASAR Mags/Controller. Cant find the pin assignment for either online.
My Lasar is i believe 1999 model. The VM1000 DPU is 1995 3rd Gen (Screw Terminal kind)
Appreciate your help.
Rob
[email protected]
Rob,
I've got the VM-1000 manual. I can send you a copy but it will be the middle of the week before. Can get to the airport to get it.
Scott A Jordan
N733JJ
Thank you Scott. That will be great.
Hope someone have the Full LASAR. The only material i found online for the LASAR is the SL1-96 Service Letter which does slightly explain some of the pins but not in details and does not cover the cables going to the side of the modified Slick Mags they use. Here is a link to it if anyone needs that Service Letter
http://rv7-a.com/manuals/SL1-96 H.pdf
