Av8torTom Well Known Member Sep 13, 2010 #1 Anyone know the dimensions of the larger rudder for the 7? Thanks, T.
E EricB Member Sep 13, 2010 #2 just measured it 60 inches tall with tips 20.5 at the top with counterbalance, leading edge to trailing edge is about 15 26 at the bottom
Av8torTom Well Known Member Sep 13, 2010 #3 Thanks!!! I got this from another builder and I don't have the tips, my rudder height along the leading edge is 55 inches. This sound right to you? Everything else is spot on. Thanks again, T.
Z zx6rrider Member Sep 27, 2010 #4 if your trying to decide which one it is, the larger rudder has a riveted trailing edge and the original is a one piece with bent trailing edge.
