Ron Lee
Yesterday a low wing aircraft (non-RV) landed short of our main runway and reportedly sustained major damage (the pilot was ok).
People on the scene reported beaucoup ice from the plane. Temps on the ground were near freezing and it was overcast.
We may see eventually from the NTSB report if it was avoidable but it made me wonder what I would do in a similar case.
Obviously, for that to happen to me I really screwed up somewhere prior to the landing. Since I am a guy, we will assume that I did screw up and I had no choice but to descend through freezing clouds.
What is my best option to not only survive but ideally save the plane?
Since I cannot quantify the ice buildup, I will assume that it is not so much that full power is inadequate to maintain level flight. I can at least stay level if not climb.
Since I have to get down due to low fuel, I have to assume a higher stall speed than normal. How much I do not know.
So I would make an approach at a high airspeed...120 MPH or higher at the airport ten miles away that has two longer runways (11,000+ feet and 13,500 feet). Flight it down to just over the runway and slowly reduce power until it settles...reducing airspeed if possible.
Thoughts and suggestions.
