woodmanrog
Is the leading edge cutout in the RV14A the same as on the other models? In other words, will the present light kits available work on our new 14 install?
Keep in mind that because the RV-14 has the light mounts riveted in a fixed position. Any method used for attaching the light to the mount has to provide a means of making aiming adjustments.
Guessing Van's is going to come out with something? Is there a timeline? Thanks.
