F FinnFlyer Well Known Member Jun 4, 2020 #1 Why do we place the landing (and taxi) light in the outermost wing bay or wingtip? Mounting it in the bay next to the fuel tank would give a shorter wire run. Is it because it would weaken the needed strength of the LE skin at that point? Finn
MED Well Known Member Friend Jun 4, 2020 #2 Probably for the same reason a mocking bird walks around with his wings spread- to look as big as possible. Most of the reason for landing lights is to be seen.
pazmanyflyer Well Known Member Jun 4, 2020 #3 I would say access. Much easier to install/work on/replace if necessary.
rvbuilder2002 Legacy Member Mentor Jun 4, 2020 #4 FinnFlyer said: Is it because it would weaken the needed strength of the LE skin at that point? Finn Click to expand... That is the primary reason.
