Delta Bravo
Active Member
Hi,
I will be installing a pulse light system in my 7A and was wondering if anyone knows of a unit other than the certified version?
Thanks, Don Bodnar
Another choice
Seems $13 (as posted by jbDC9) is better than B&C, who sells the same thing for $22; From what I see they are the same part and you can wire it to use just one.
Another option:
http://www.periheliondesign.com/wigwagmnl.htm
-OR-
http://www.periheliondesign.com/wigwagdmnl.htm
Both of periheliondesign's flashers are more expensive options than an auto flasher or emergency head light flasher. Better? You be the judge. The lower cost and nlighter the better.
wig wag certified version available cheap
I have the certified model. For reasons that could never be determined, it worked for the factory, but not for me, so I un-installed it. It even has a hi-low speed setting switch. Make me an offer.
