Of course you say? Don't understand why your covers don't fit. As you can see, I installed Grove Airfoil gear and with very little modification the stock covers fit the airframe just fine. Are the standard Grove (non-airfoil) type gear legs comparatively thicker? What am I missing?I have installed Grove gear. I then went over, grabbed the covers that go on the underside of the plane, they of course don't fit, the grove gear is to thick. Any ideas as to what I should do.
