wfinnell
What kind of tape works best for securing the brake line to the landing gear? The drawing specifies "adhesive tape". I checked in my tape bin and they pretty much all have adhesive. I realize I'm probably overthinking this, but I had this mental picture of electrical tape all gooey and falling off inside the faring... I thought maybe someone has a better idea. Always a lot of good ideas on VAF.
JFUZtLrGyujoZ-LkwFc7ZDUERtwBOjlsP7NslcWBT2H2x7859WbrkpjuvK1mWKWsatlkYbVSZ4HpJGdLlrb02wghG3eMZDB2kCt8OI4vNg__AIir9CqQjXJgtLX0Un6l0lu7R960hdPAVkDhZ8hOaMRriBCUNEM-488Jdu1cLODmB9eTRGyS9pKcN2EPTW1dZbkoZxZ1GTsyGZgby6m4QorA9wZbFBrq3vCvxschmgptKf7mTdmnMAP6EZZJCtCsIMIhyFpriWou81kufLkj-P8BiejlBnJ2Y7GcwED_7GXxWqrgpPMdaAbswbdOy3GInPYH2YcMQdYeAcaeLz8_hlsHFH8s-6Qi-M3mL4La4aZrMdAQJVo6nTdXbU8AqAkEb8y5T8XASCrLTqHp2sH1PW5yPUwAyfzVjg8JLC0Kziop9pQqo1tsBjAGyJbLDXR7W0St8oqWk7Y696c20wIcQjYu2p1vszxN1UBj7x4OI9eUTz56YyuEuBmrlOskaO1fCG57-5l0rfw_ycOBUhQPxbaim2EOrV01BdGVx0sKqB0BzG_P_gge3kQZfB536Xq9mx-RONHsQwgf84oaevmjrpAKQAg17KISIrZMlD-RdTJilZCZjbw=w449-h334-no
Uq_GYZRZqoLXRuIcORVM6Q8Ptj2XEphLooyUTm2vH4mKnCoGKL6n4a4kiwFsiwTOaTOIUMBpkp_tIco5kO125PF_yZT6UeAg0N6nnpcvIfyQ_W9Sh3NGwSR3ADXicAN3f8U8TjdLntlVxzQ6JHdxowomJ0JWsMZz5CvR6XQYMELAelYQp_rSrZweUCO0FQ-N3qwXdZ4ui8x2bARM7FoX7KJKHPCI5twaIjEyCifyxFZ6yijWU4YkbKOtLRdsGCXvB15CHCzyQi16aPeSFazO4DVxyI_ybCBXCdgnqlLsDNAHKzuaGNPCakKmW-l66JUcs5ZGpzJMfXHNJkE-aue-bCwT8vPJghLtb8qPQknLE5bPkA8T32WwYh4aeCov-MHmMf2JC55DCDAzZs_McCtd6bHr36jN1pCs5BB4DcRD7lN1wtwGKNQVhaeFGL8NzUf-VJxoDqqPOcI_0FWqJJAu4mDuq9iMfFWgs1aI50X8F-MuM2SJcS_kAGjCFO-MPRf3Pvks4UoXhVjshIHJedYIRNSE5FOuk5LQ2G4N6z6M7rFD6LTwwQLRP4sjOnZK973J4XtFVFxTQ279GETFGvnYiho95amF-0lOdeYmUW9ZiAyTHWQ=w640-h480-no
Actually a good quality (3M, don't use discount store stuff) electrical tape works quite well and lasts a long time covered up by the fairing.
It also doubles as a rub protector between the inner surface of the fairing and the gear leg.
Ditto.
Same here as Scott. We have an "A" so three legs. The good stuff from 3-M that comes in 5 or 6 colors seems to last the longest and comes back off the best of any we have tried. I look at the fairing and will rap it around the leg some times three raps, some times 6 or 7 raps, so that the leg will not rub the fairing. We split some of the clear plastic tubing and make a segment maybe 1 1/2" long to go around the brake line and then just rap that to the gear leg with just a slight pressure from the tape as we rap it. Not to tight and not to loose. I like the green stuff or brown, just looks nice on that spot.
Hope this helps. Yours. R.E.A. III #80888
Gorilla tape
The same stuff Vans uses when packing sub kits. Sort of super duct tape.
+1 for the plastic tubing. Allows brake line to move at a different rate then the gear leg.
