I used a K-Sun and very pleased with it. Also a bit pricey. Seems any of the ones that will do heat shrink tube are more expensive.
I received a flyer from the Hawk Labeling Systems on a new K-Sun called the BEE3. Very reasonably priced starting at $79.95 and going up from there depending on what accessories you get with it.
Their number is 1-800-458-3430. To bad this unit wasn't available when I bought mine as I paid way more!!
The drawback to all of them is the printable heat shrink tubing cartridges are expensive.
Well worth it as it makes such a nice, professional job. Also when you need to get back in there for any reason, it sure makes tracing and identifying wires easier.
Ted
Labelcity has just put the RhinoPro 5000 on sale with a 50% discount.
http://www.labelcity.com/eonline/itemdesc.asp?ic=18189
Rhino Pro 5000 but had lots of problems with the heat shrink tubing cartridges. Finally gave up and used other methods. The cartridges jammed up and wouldn't print.
Any electric supply center has numbers that you roll around any size wire. Number each end any any place between. Then write down the number and what it is for. Total cost about $5.00...................... I can see why RV's are costing $100,000.00 to build.
And what do you do with this tool after your aircraft is finished?
