KX155, Dynon
Thanks, sorta figured but sure was hoping it would work. Now I need to install a VOR head.
Removing KLX135, installing KX155?
Struggling with pin out nomenclature difference for the comm side. No audio panel but do have a intercom. Anyone familiar with the two? KLX135 pins 2, 3, 4, 5, 13, 14 vs what on the KX155??? Thanks
Hi Dan,
The KLX135 pins 3 and 4 are mic hi and mic lo and correspond to pins 2 and avionics ground on the KX-155 P401 connector. KLX135 pins 13 and 14 are audio out hi and lo and correspond to pins 9 and K on the KX-155 P401 connector.
KLX135 pin 2 is the interlock pin; not sure what that corresponds to on the KX-155 if the 155 even has an equivalent (I don't think it does).
KLX135 pin 5 is sidetone audio; this is included in the comm audio out from the KX-155 and piped through pins 2 and 6 on the KX-155 P401 connection.
I hope that helps.
Thanks!
Brad
