sglynn
Has anyone replaced a King KT78A with a King KT76A or KT76C? My KT78A is weak and I am considering the uAvionics Tail Beacon for ADS-B out. So I need my transponder to be good. The KT76A or C appears to be a strong transponder with 250 watts output up to 30,000 feet.
So is the KT76A truly a plug-n-play replacement for the KT78A? My reading says they are interchangeable with no wiring changes. But what does that mean? Is there a setting or something that matches the transponder to the encoder? Is it something I could do without an avionics tech?
thanks
thanks
