reconaviator
Member
High all,
I was wondering if anybody has had issues with a transponder kicking the HS34 off the DSAB network. My transponder coax and power wire is shielded and grounded (although the coax is older) and I have not interference from transponder through any audio. But when I turn on the transponder it kicks the HS34 offline, it is solid onther than that. I still need to trouble shoot the mode C most likely wiring is wrong on the converter module in between the d100 and kt-76a,, not sure if this could be causing it.
Any thoughts or words of wisdom
Scott
PS Dynon said to twist and or shield the DSAB wires between the hs34 and d100
Scott
