Yes, I have this exact setup. I had no issues installing it except we had also installed a big home improvement store handle on the rear of the canopy through the overhead frame and that necessitated having the shorten the shade track slightly which just means the shade is a little less taught when fully extended. The wires that the shade is suspended on clear the slider rail on the fuselage even with the supertracks because you're tipping the canopy up when you slide it up the S-bend onto the higher track.
