Hwood
Seeing a lot of stuff about parachutes, canopy jettison, etc..... I was just curious if there has ever been any documented case of someone successfully jumping out of an RV?
Here is one method that has been demonstrated
So I have read all the accident reports on all RV's except I haven't finished the RV-4's. This is the one that was the most chilling.
See FAA Accident record CEN11FA634
The pilot?s in-flight loss of control. Contributing to the pilot?s fatal injury was his failure to use the available restraint systems, which resulted in him falling through the open canopy when the airplane inverted.
The private pilot was flying his experimental home-built airplane on a visual flight rules (VFR) cross-country flight. While en route, the pilot requested VFR flight following services from air traffic control. A review of radar data revealed that, at the time of the request, the airplane was level at 8,500 feet. About 6 minutes later, radar and radio contact were lost. No distress calls from the pilot were reported. A witness who was working near the accident site reported hearing a very loud revving engine noise. When he looked up, he saw the airplane flying upside down. He also stated that he did not see a cockpit or a pilot in the airplane. A few seconds later, the airplane passed behind a stand of trees and out of sight. He went to the impact site and found the wreckage but not the pilot.
First responders reported that the wreckage was mangled and spread across a soybean field in a southerly direction. Ground scars at the accident site indicated that the airplane impacted the ground at a high velocity in a wings-level, slightly nose-down attitude and inverted. The engine and propeller assembly exhibited evidence consistent with high power at impact. All of the flight control surfaces were accounted for at the main wreckage site. Flight control continuity was established from the cockpit to all of the flight control surfaces, and no evidence indicated that any of the flight controls were disconnected or otherwise separated before impact. The pilot?s body was found about 1 mile northwest of the airplane wreckage. Canopy parts were found about 3/4 mile northwest of the wreckage, and various pieces of the acrylic canopy were found scattered for about 1/2 mile southward. One of the canopy roller tracks was not found. The found roller track exhibited deformations about 8 inches aft of the forward ends on its left and right sides consistent with the attachment rollers being pulled from their tracks in an upward direction. The pilot and copilot lap seat belts were found attached to their respective anchor points with no evidence of overload failures or stresses on any of the latching blades or buckles consistent with the buckles not being latched at the time of impact. The pilot?s autopsy findings did not show any evidence of incapacitation, and toxicological tests were negative for drugs and alcohol. The on-scene evidence indicates that the airplane was likely controllable and that the engine was producing power at the time of impact. Given the location of the pilot?s body and the acrylic canopy parts and the witness?s statement, it is likely that the pilot lost control of the airplane, which then inverted, and that the pilot subsequently fell through the open canopy. The reason for the pilot?s loss of control of the airplane could not be determined.
Not quite sure...but I wouldn't think that would fall under the "successful" category.
Just sayin
Depents on the question
Did he successfully depart the aircraft? Yes
Did he have a successful landing? No
But it does answer the question about what to do if the canopy will not depart or open.
Getting out
I recall reading about an unfortunate incident in which an RV-8 in-flight caught fire. The desperate pilot was able to exit the aircraft but had no parachute. This obviously was like the prior case discussed with an unsuccessful landing, and even more chilling in my view. Anyone know the details?
Curious
Thanks Bill. I didn't know about the Redbull accident. That is encouraging as was the Hawaiian ditching.
