I think i got mine from alliance coatings, El cajon, ca.
great customer sevice
Thanks folks, Jet flex is a two part poly, they also offer a water based one that some of you may be referring to as not as durable. The traditional poly is extremely durable I just do t have a contact now that I’m out of the business.
I found the Water Based stuff to be quite (very?) durable as long as you let it cure for a few days.
That's the one. Jet Flex Solvent Based. Durable but not as tough as a 2K Epoxy. Plus that Catalyst turns to a rock in no time and you get to buy more. It's not cheap. It lasts longer in the freezer or if you have a nitrogen bottle to displace the C0² in the head space. Spent lots of time with Tech Support.![]()
Sounds like you were in the biz so maybe I'm way off base. I did spray my interior with it. Pretty mad when I was prepping to paint and the catalyst was hard as a rock.
